TCS and SBS off lights on
All - I have Touring 2017 CX5 and noticed that TCS/DSC and SBS off lights are on in the instrument panel. These are not flashing. It happen on the day when I drove on a freezing road (not snow). Not sure if this is related. I tried SBS off and on from infotainment but no help. Any ideas that I should try before taking it to Mazda dealer.? TIA
Ok well the first thing would be to use a Diagnostic scanner and connect up to your OBDII DC and see if there are any codes and then go through the problem check list. So, this likely means you are needing to go to a service shop that has qualified Technicians. There are some good shops in your area of Portland that are ASE Certified shops. Or naturally you can go to MAZDA.
jamcc
12-26-2006 01:11 AM
