US/Canada and International Engines
Old 02-07-2015 | 12:43 PM
Sid777's Avatar
Default US/Canada and International Engines
Engine oil recommended for US and Canada is 0w-20 and for international it is 5w-30. Anybody know if the engines are different?
Old 02-07-2015 | 12:50 PM
hixx's Avatar
Oil viscosity differences in regions is generally due to temperature variations. Hotter climates use thicker viscosity oils. Colder climates uses thinner viscosity oils. The engines/transmissions/differentials use different viscosity oils depending on the average temp of the region even though they are the same exact parts. Use your best judgment.
Old 02-07-2015 | 06:03 PM
Sid777's Avatar
I see the 8th place in the VIN is the engine code. USA and Canada codes are different than Mexico. Y=USA/Canada 2.5 liter, E=USA/Canada 2.0 liter. Mexico codes are numbers. So, USA/Canada engines are different. I don't know how different though. I'm thinking they may have design differences for the 0w-20 oil so I guess I'll stick with that unless someone can tell me different.
Old 02-07-2015 | 06:14 PM
hixx's Avatar
Oil viscosity is based on bearing/piston to cylinder wall clearances/etc. Any noted difference in engines would only relate to fuel/air ratio's which are different from country to country.
Old 02-08-2015 | 06:05 AM
For NZ & OZ the chassis numbers,
JM0 = Built in Japan,
BK = The model ( 1st Gen Mazda 3 ) - BL = 2nd gen M3, BM = 3rd Gen.
10F = Engine, (2.0 ltr engine ) 103 = 2.3, or 10L = 2.5,
100 = Pre facelift, or 200 = facelift,
123456 = Unique ID number
JM0-BK-10F-100-123456 17 DIGIT CHASSIS NUMBER.
Old 02-08-2015 | 06:40 AM
Sid777's Avatar
So you think there's no difference in the blocks, oil pumps, lifters, bearings, etc. between a USA/Canada Mazda CX-5 engine and those sent to other countries and a USA/Canada engine can safely use 5w-30 motor oil? Ours is using about a half quart of oil in 2,200 miles. I have some Amsoil 0w-30 I want to try in it to see if that would reduce the oil burning some.
Old 02-08-2015 | 07:45 AM
hixx's Avatar
No difference in the engines other than emission standards of the countries they are bound for. It would be mind bogglingly expensive to change the internals of every engine for each country and no reason that i can fathom to do so to begin with.
Old 02-08-2015 | 07:59 AM
It's the "0" in 0w-30 that will burn. 0 is zero weight. If your engine rquires "0" weight oil you could go to a 5.
1/2 a quart loss isn't bad, read: https://www.mazdaforum.com/forum/gen...ls-0w__-32291/
Old 02-08-2015 | 08:41 AM
Sid777's Avatar
Thanks but I don't know why the 0w_ would be the problem with oil use. That's supposed to be an indication of the oil's viscosity at below operating temperatures. At 100 degrees C, the Amsoil 0w-30 viscosity has about a 20% higher viscosity than the Castrol Edge 0w-20 recommended by Mazda.
Old 02-08-2015 | 09:05 AM
Not really comparing apples to apples.
2 different oil weights.
Amsoil is a premium oil, no doubt. 0 is definitely thinner than a 5
If your engine requires 0w20, you definitely could go with 5w20 synthetic.
You also may be able to mix half of 5w20 and 1/2 of 5w30 using Amsoil.
A good article on synthetic oils with some charts etc: Synthetic Oil Advantages - Mazda Forum - Mazda Enthusiast Forums/
Quick Reply: US/Canada and International Engines
