Wind noise?
Old 04-04-2012 | 09:45 PM
rodster13's Avatar
Default Wind noise?
Just got my CX5 a few days ago. I noticed wind noise from one of the doors at HWY speeds. I have an appointment at the dealer to have a look. Anyone else notice this?
Old 04-04-2012 | 11:43 PM
CX-SV's Avatar
None noticed so far since purchase date, 3/18.
Old 04-05-2012 | 01:28 AM
MathewR's Avatar
We've not had any issues with excessive noise. The upgrade to the CX-5 has made our conversations take place at normal volume levels when we used to have to speak up. If you're getting noise I'd say it's atypical.
Old 04-05-2012 | 11:58 AM
CX-SV's Avatar
I've found wind noise to be minimal cruising at the typical 70-80mph around here. But sensativity to crosswinds is significant at freeway speeds.
rodstar13 - Please let us know what the dealer says after your appointment.
Old 04-16-2012 | 03:45 PM
rodster13's Avatar
Default issue solved?
Upon inspection at the dealership, A plastic trim piece was slightly warped and not sitting flush against the window. The turbulence caused the hiss emanating from that area.
The piece is vertical and borders the fixed and movable windows on the rear passenger doors. The tolerance was about 2x what it should be. They ordered the part and it's on it's way for a future service appointment.
Old 04-16-2012 | 04:10 PM
CX-SV's Avatar
Rodster - Thanks for the report. Good info.
Old 05-25-2012 | 09:27 PM
rodster13's Avatar
Default Bummer, the trim piece didn't solve the issue.
Uh Oh. It's officially turning into an obsession. I'll have to isolate the issue myself. I believe it can be fixed because the other door doesn't do it. I'll report back when I have something figured out.
Old 06-28-2012 | 05:58 PM
CX-SV's Avatar
Can we assume it's all fixed now?
Old 08-05-2012 | 12:59 PM
rodster13's Avatar
Default Not gone but making progress
I've improved the noise in the worst area by shimming under a distorted area under the door gasket. Maybe they are having tolerance or quality control issues with the early gaskets? The gaskets are critical and very sensitive to geometry problems when compressed.
I'll ask the dealer to change all the door gaskets if I am not satisfied with the noise levels. I admit I'm a head case about things like this.
Old 08-18-2012 | 01:42 PM
rodster13's Avatar
Smile this helps!
mazda p/n KD33-V3-700
I found them at a dealership online.
park mazda
Akron OH
Just installed this morn. They look killer and are like smoked glass. It strikes me how low of a profile they have. Looks to me like there was a lot of wind tunnel testing done, which I think the customers will appreciate.
Sound-wise, I'm guessing 0.5-1 dB improvement across the frequency range. As a reference, a CX-5 is 3-4 dB quieter than a 3 hatch.
The install isn't bad but it absolutely needs to be right the first time. Take your time!! I recommend raising the window into it's fully closed position before doing the final adhesive press.
Quick Reply: Wind noise?
