Cooling Fan Modules
Cooling Fan Modules
Just to let you all know.....I changed both fan modules and the fans now operate. Now if I drive up a long incline in 30 deg weather, idle for 2 min before shut off, the temp only climbs to 228. The fans do operate while in the 2 min idle period. They DO NOT operate once the key is turned off. When the temp climbs to 228 while key is off, and then turned to on position, the gauge reads in the same spot as normal driving temp which is 5 notches from the bottom. Where as before new modules, the temp gauge would be pegged to hot max.
The dealer told me they would not work on my car anymore about this issue, I think because the service manual says to check the sensor, relays, fan motors, and if all ok it must be the modules, but without a way to test them, so the dealer probably felt a $700 parts bill just to "guess" wasn't worth it so they opted to not fix it at all.
Since I had tested all the parts I figured what the heck its gotta be them, its all that's left, and it was the modules.
I will be in contact with Mazda legally to force payment.
karlt10
07-27-2014 01:45 PM
Larry 62694
05-10-2006 11:41 AM
ozmazda1993
10-04-2005 05:58 AM
