Fuel filter
Old 04-01-2016 | 06:41 AM
shipo's Avatar
Thanks, good to know.
I find myself wondering if it is because of the potential of dust in some regions more than fuel quality.
Old 04-01-2016 | 02:49 PM
fixit's Avatar
I think the CX7 has one too, but you have to take off the fuel tank to change it.
Which is a p*#s poor design on Mazda's part.
I did see a video of a guy who went 300K before he changed his fuel filter.
It was real dirty, but his car was still running fine.
Old 04-01-2016 | 03:03 PM
shipo's Avatar
It is actually a very good design, hence the fact virtually every manufacturer in the world does/did it that way. Just because a filter is dirty in no way means it isn't doing its job or needs changing.
Old 04-01-2016 | 05:04 PM
fixit's Avatar
A good design is when the fuel filters were under the hood and NOT in the fuel tank.
Fuel filters in the tank are for extracting lots more money from consumers.
Old 04-01-2016 | 05:15 PM
shipo's Avatar
We're going to have to disagree on this one; since the fuel filter was meant to last for the life of the vehicle, then putting it in the tank discourages someone from messing with it.
Old 04-02-2016 | 03:03 AM
fixit's Avatar
Since you gave bad advice on this thread, I am suspect on your advice on other topics.
As a senior member, I feel that you did not do enuf research.
You appear to be very active in defending Mazda's manufacturers.
There are at least 7 oils that meet the specs for my vehicle.
JWS3309 is a standard that the fluid must meet which is in my owner's manual.
Castrol Import Multi-Vehicle Fluid
Toyota T-IV
Mobil ATF 3309
NAPA - AIC ATF0T4
AC Delco T-IV
Ford - XT-8-QAW Premium Automatic Transmission Fluid
AISIN - ATF-0T4
All meet the standard (the Toyota, Mobil, Delco and Ford are all the
same Mobil 3309 just badged for those companies)
Old 04-02-2016 | 07:54 AM
shipo's Avatar
Defend Mazda? Hardly. As for my research, I'm an engineer and have worked for three different automobile manufacturers; I have a pretty good basis for the recommendations I've made. That said, you've come to your conclusion, so I'll bow out from here on in; have fun replacing your fuel filter.
Old 04-03-2016 | 09:35 PM
fixit's Avatar
No filter on it, just the in tank sock. Doesn't really need one either.
From the book it also looks to have nylon fuel lines. Nothing in the
system to rust.
Old 04-04-2016 | 04:37 AM
Are you sure? The plastic body that surounds the pump is the filter.
Old 04-04-2016 | 08:17 AM
fixit's Avatar
