Fuel filter
#21
It's considered a "strainer". No need to futz with it unless it's giving you a specific problem. I will defend Mazda and I'll also throw them under the bus if they deserve it.
Heater Core Replacement in a Mazda 3. Step One, Remove front doors. huh....
#22
You're singing to the choir.
Had a Mazda Protege with 242,000 miles when I sold it.
It was still getting 40/29 miles per gallon.
It had the original starter, alternator, manual transmission, fuel injectors, and many other parts.
#23
06 Mazda 5 has a fuel strainer
Listed on RockAuto as part number AIRTEX FS246
I have a 2005 Acura, has a fuel filter. And a 2003 Jeep, has a fuel filter. Difference between the older cars and "newer", is that older models had a in-line filter that was easily replaced. Now they are mounted or attached to the fuel pump itself, and generally require either pulling the tank or accessing it thru a hatch in the rear compartment or under the rear seat.
Granted, the gas itself may be of high quality now when it comes from the refinery. But from there it is put into a tanker, hauled to a storage facility, put into another tanker and hauled to a gas station where it is put into underground tanks. Then pumped thru a pump, which is SUPPOSED to have a filter, but may not. Each of those steps are an opportunity for contamination either thru dirt or condensation. To assume that there is "no need" for a fuel filter on a vehicle of any kind (hell, there is one on your lawn mower) is just plain silly.
#25
Ok. First pick on Rock Auto: 2015 Chevy Impala. Part: ACDELCO M100152
This is a copy and paste. Note the third bullet comment:
Features
Designed with guide rods to retain proper alignment while reducing pinching
Include a reservoir and jet pump to prevent fuel pump starvation when the fuel level is low
Strainer is placed inside the module to help reduce the chance of puncture
Acetyl plastic for good high-alcohol fuel tolerance
Electrical connections are designed to help eliminate below-cover burning due to vehicle vibration
GM-recommended replacement part for your GM vehicle’s original factory component
Offering the quality, reliability, and durability of GM OE
Manufactured to GM OE specification for fit, form, and function
Features
#28
Of course they will. Dealers are the ones that will make more money doing the repairs. Just 2 months ago (or less) several MAPCO stations here in Tennessee were caught, and admitted too, dispensing contaminated gas. Some vehicles had to have tanks drained and filters changed. Some had to have tanks drained and injection systems changed.
#29
Perhaps you will read this post of mine and give me an idea? https://www.mazdaforum.com/forum/maz...94/#post157491
If you have input, I'd appreciate it.
#30
Features
Features
Sure, no one makes filters anymore. :-)
New Denso Fuel Pump Strainer Kit Will Fit Mazda Vehicles DEN1300 Maz | eBay
