Oil Change
Oil Change
I just got a cx-7 for my wife. Its a 2010 with the 2.5 liter, no turbo. Has anyone done an oil change on one of these yet? Does it have a canister oil filter, or the normal spin on filter. My Mazda 3 has the canister, and its a little messier than the spin on types. Anything else I need to know about routine maintenance on this thing?
I have the CX-7 with the turbo, had the first oil change done by the dealer it was FREE, I like free. The service person shared with me it's not the screw on type of filter any longer, but it's the canister with spring, rubber O-ring and a lot more messier than normal. They shared also not to have inexperienced people do the oil change, might crack the canister and have oil leaks. On my next oil change I'm switching to synthetic oil and change out every 5 thousand.
Sorry about my explanation of the 5,000 oil change. I would change the filter out on the first 5,000 add a quart then go another 5,000. I would change out the oil completely @ 10,000 and repeat from there after. I agree synthetic is expensive to run, but with my last four cars that seem to work for me.... up for any suggestions !
When my wife and I bought our Jetta in 2006 (18 miles on it) the dealer and recommended that we change the oil close to 5k and then every 10K. I don't know why but we have done this ever since. Mobil 1 synthetic. No probs. Here is an independent review of oil filters.
http://people.msoe.edu/~yoderw/oilfi...lterstudy.html
Why synthetic? In almost all cases, you will not notice any difference in milage or performance between normal and synthetic oils. However, four cylinder engines work hard, especially modern engines with variable cam timing that use oil pressure to work and benefit with a free flowing thin oil such as 5-20 or even 0-20. Thus installing a synthetic oil that flows more freely at startup and with stands more heat without cracking and forming varnish can't hurt.
Come-on; an extra $40 every 5000-7500 miles ain't too bad for just that extra peace of mind.
Runs rich? I seriously doubt it runs any richer at WOT (and no richer at all at partial throttle) than any other car, and even then any fuel that makes it way into the oil should quickly evaporate out. Said another way, a short 5,000 mile OCI is worthless.
mazpro00
11-14-2013 03:54 AM
daveo
01-01-2006 12:17 AM
