SCR Malfunction
SCR Malfunction
Hi,
I have an error coming up on my 2010 Mazda CX 7.
I have topped up the ad blue and cleared the error code but I am still getting an SCR Malfunction.
When running the error it comes up with U0042.
Type: Network-Network data-ISO/SAE controlled.
Description: Invalid data received from ECM/PCM "B"
Does anyone anyone have any solutions or ideas on what this could be or how to fix it.
Would this be best to go through Mazda or would a normal mechanic be able to deal with it?
Thank you.
Thank you.
I used torque (lite) for the scan with an OBDII. Do you have a recommendation for a better scanning ap?
Does the pump not working damage the engine?
It lets me reset the ad blue fill warning, so that avoids the car restricting itself and the final point of it nof turning on.
I know that you can remove the fuse to stop the error coming up, but I obviously don't want to do that if it is going to damage the engine, not the ideal solution I know.
Thanks
Thanks
Same here, hopefully resolved.
Hi,
Thank you.
Thank you.
found a local mechanic who said the codes indicated dpf reset required. He did this (burnt soot out) put in a new battery and we have our car back.
Hope this helps some that are battling this potentially expensive issue.
