roof rail Crossbar noise
Reduce wind noise
Here are a few tips to get it improved:
1. Adjust the bracket position back or forward a bit to get the bar tilted.
2. ChecKing the brackets around area to avoid some gaps or improper positioning brackets.
3. Use a string to wrapt the front bar at 45 degree to test of the noise comes from the top surface. If wind noise is reduced significantly, then applying a striped rubber strip to the front bar or both to get it fixed permanently.
hope this helps
msvadi
07-13-2012 05:15 PM
