07 CX9 has low idle, sometimes will die
Old 09-21-2011 | 04:29 PM
Monty24's Avatar
Default 07 CX9 has low idle, sometimes will die
Recently my CX9 has seemed to have a low idle. When I am in park the idle will occasionally drop very low, like 3-400 or so, then the car will catch it and jump back up to normal. Every once in a while it drops and the car doesn't catch it and dies. It does not give a check engine light, and restarts fine.
It only seems to happen on very hot days, the cars temp is right at halfway, not overheating. I do have the AC on and it does seem to drop rpm when the radiator fan kicks on.
That is all i can think of. If you have any advice on what I should look at first, it would be much appreciated.
Old 10-05-2011 | 05:28 AM
dieseldriver2003's Avatar
It sounds like the engine is not getting adequate fuel? Maybe the injectors are dirty? How about you plug in a ScanGauge II and watch some data coming from the ECU?
kongquistador
08-04-2013 06:22 PM
smokeyou
03-19-2010 12:06 PM
SlowG60
12-12-2009 01:14 AM
sc00byd0034
10-19-2009 12:05 PM
