2007 cx-9 3.5L oil Leak?
Okay at first there was a misfire cylinder 3, it was bad ignition coils. I replaced the coils all of them in the spark plugs Miss fire went away everything's great except for now there's a full leak on the back side of the motor. I don't know where it come from but it wasn't leaking before I had to replace the spark plugs. So I replaced the valve cover gaskets and all the other little rain gaskets around the spark plug tubes and two no avail it's not fixed. Where can my oil leak be coming from that is above that exhaust passenger side back side of the motor. And has anyone ever dealt with something like this where it was just the spark plug and then you put it all back together and now there's a leak
