2014 CX9, Trans is shifting sluggish at times
While the disconnecting of the battery may have appeared to correct the OPs issue, I am more incline that it was only coincidence, and the original problem was not resolved?
I would also be VERY careful if or when considering "FLUSHING" a automatic transmission and if it does need to be done have the service done from a shop that has the specialized Transmission service equipment to do it. I do recommend at least filter and pan fluid change if anything you can have a look at the pan, drain plug magnet and the anything else unusual. .
