ABS Sensor Bolt Broke - Need Suggestions
I have an AWD 2013 CX-9. While replacing the rear passenger Wheel ABS Sensor, I broke the the head off the 10mm bolt that holds the sensor to the hub. The issue I'm having is that I can't quickly get a replacement bolt. The dealer said it will take 4 or 5 days because they're not in the distribution channel. After looking around the Internet, I've seen it suggested that this is a typical metric bolt that you can buy at Napa, or even Lowes. I suspect this may be correct, in the sense that the part is common enough that mechanics just have these laying around - which is why it's actually hard to get. The part number I have for it is 99458-0612.
If anyone could shed some light on this, I'd really be be grateful.
Thanks!
Thanks!
Thanks!
Thanks!
