Aluminum Alloy Wheels Look Dirty
Old 07-19-2009 | 06:01 PM
boyd's Avatar
Default cx9 stained wheels
i just purchased a 2008 cx9 gt awd.
the dealer didnt have time to clean because it was so late.
i didnt care because i like cleaning cars anyway
when i went to clean the wheels they appeared stained.
i tried different cleaners and polishes but it looks like it is under the clear finish.
does anyone have any suggestions?
Old 07-19-2009 | 06:09 PM
boyd's Avatar
Default stained wheels cx9
i too have stained wheels.
have you had any success with yours?
Old 07-22-2009 | 09:33 PM
howardru's Avatar
This is a known defect with the wheels. There was a paint problem associated with certain batch of tires.
I am trying to find the TSB but not having much luck at this point.
Check the Mazda 24/7 Forum. this one is lame
Old 07-22-2009 | 10:33 PM
Lame? Sorry but I take exception to that. I am a Moderator over at 247 too. I like both forums but for different reasons. And in some ways, I like this one better. There are fewer ******* on this forum for one.
As for your wheels: There was a similar issue w/early 3 series cars also. The clear coat was porous and allowed water and dirty to infiltrate. Needless to say, they corroded beneath the clear.
Dealers were replacing the wheels no questions asked. I would imagine that if it is a known issue, the same is, or will be true for the 9's.
Call your dealer. Print out this thread if necessary and take it with you.
My '02.
Lame... indeed.
Old 07-23-2009 | 10:06 PM
howardru's Avatar
My '02.
Lame... indeed.
My apologies...Lame was not the proper word. But, as you MUST admit, there is very little activity on this board compared to 24/7 where there are multiple postings to multiple threads every day. Or Edmunds where there are at least a few per day. Where this forum is once a month sometimes or on a good week, once per week.
Lame, no....my apologies, just not as active or seems to attract the "knowledge" crowd you find on the other 2 forums.
Old 10-23-2009 | 02:18 PM
thx4nuthn's Avatar
Default CX9 wheel discoloartion
I too am having the same issue and my dealer and Mazda are basically trying to say that it's chemicals we use when washing the car that causes this. Apparently there was a bulletin about it but I never received anything.
Stay tuned as I am digging deeper and will need all your help when this happens.
In the meantime, call Mazda Corporate 800-222-5500 and complain.
see below:
Some automotive cleaning products contain strong acid or alkali. When these types of cleaners are used to clean the wheels on Mazda vehicles, the chemicals contents penetrate the clear coating of the wheel surface and damage the paint under the clear coating. The damaged area has the appearance of dark stains.
Use extra care when cleaning wheels. The following are guidelines to follow when cleaning the wheels.
§ Mazda recommends using a mild soap or neutral detergent as stated in the owner's manual under Appearance Care in the Maintenance and Care section.
§ DO NOT use a cleaning products containing strong acid or alkali contents to clean the wheels.
§ DO NOT apply any type of specialized wheel cleaner to the wheels when they are hot (such as after driving the vehicle or if the vehicle has sat in the sun). Ensure wheel temperatures are the same as ambient temperature before cleaning.
§ Within 15 minutes after any cleaner is applied, rinse the wheel thoroughly to completely remove cleaner.
§ Stains on Mazda Wheels caused by improper cleaning are not covered under the Mazda Vehicle Warranty.
Old 10-27-2009 | 11:52 AM
devo's Avatar
Default CX-9 Wheel Stain
I have the same issue with my CX-9 GT 20" rims being stained. Has anyone been able to get them replaced under warranty? Is there a Technical Service Bulletin? I have had zero help from Mazda our the dealer. This was in no way from any chemicals applied as Mazda is trying to imply. Own up to it Mazda. This is a problem other manufactures would resolve for customer satisfaction.
Old 01-27-2010 | 10:44 PM
snowman's Avatar
Default 20" Wheel Staining
I too have a set of 20's that are stained. car has 27K on it. Never been through a car wash and always washed with Meguiars soap and waxed using meguiars. Dealer (Bankston Ford/Mazda in Fort Worth) states their is nothing they can do and cited the TSB. I asked how far I need to take this up the chain and she said call Mazda. Quite Frankly I believe the strong chemical line is BS. I lean more towards an incorrect or porous clear coat. There are thousands of cars that are not hand washed that go through car washes every day with alloy wheels and never have a problem. I think this is Mazda's way of takeing the easy way out. Pretty **** poor customer service on their part. I had a guy at American Wheel tell me the that the strong cleaner response was a bunch of BS. If anyone has had success through Mazda, let me know.
Old 03-02-2010 | 03:32 PM
See Ex Nine's Avatar
I have this same issue. I would really like to get this resolved, but I would prefer to have the TSB as ammunition before going.
Anyone have the info?
Old 02-25-2019 | 11:23 PM
Wazza58's Avatar
Hi Folks from down town Australia..................
We have a 2018 Mazda MX5 RFGT and a few days after a service last week we noticed that all four alloy rims had these blackish stains which looked like sling / cast off from the tyre shine that the Mazda dealer applies to the tyres after servicing the car ( they wash the car and put tyre shine on to make the car look pretty !! ) Some areas of the rims also looked like the finish colour of the rims was fading and the stains appeared etched into the clearcoat or underneath the clearcoat of the rims.
Took the car back to the dealer and they too thought at first it was sling / cast off from the tyre shine they applied so they took the car away to see if they could clean the stains off. The service manager came back after about 30 minutes and explained that the stains were not sling / cast off and had nothing to do with the tyre shine they had applied a few days earlier.
He explained that the stains were actually under the clearcoat and coming through the rim's finish colour from inside the rim itself. He advised that they had seen similar problems and staining with Mazda 6 alloy rims ( which apparently have the same colouring process and clearcoat as the MX5 rims), but he had never heard of the same happening with the MX5 rims and that this was their first occurence.
He showed me a Mazda 6 rim which was replaced by Mazda and the staining was exactly the same as the staining coming through on all 4 of our MX5 rims except for the fact that the staining on our rims is much more invasive and covers more of the rims. In some places it appears that the coloured finish of the rim is actually fading and other areas are blackish looking spots and run marks.
The service manager advised that Mazda believe the heat emanating from the brakes is affecting the colour finish and the staining is coming through from the inside of the rims and under the clear coat.
He has taken pictures of the rims and is sending them through to Mazda and believes that Mazda will have to replace the rims as they did with the Mazda 6's that have been affected by this apparent fault / issue.
We can only hope that Mazda take ownership of this fault with their rims and they replace the rims without delay.
Has anyone else had this problem or heard of this with the MX 5 ???
Cheers & Beers from down under folks ........................Waz from Oz
zr1mark
06-24-2009 06:29 PM
gjt101
06-23-2008 03:58 PM
nadajoey
11-07-2007 06:56 PM
D9ly
09-16-2006 06:47 PM
maz3sport
05-02-2005 11:04 AM
