Auto window
Auto window
So, I took my CX-9 to the dealer and they programmed the second remote that I never received with my car. My auto down and up window function does not work not to mention the 2 step down function. I opened the manual and followed the procedures to re-initiate both options and they did not work. Anyone else have this problem?
RE: Auto window
Lindy... I'd run into this when our battery was jumped ( airport parking... long story )... and had to reset the window functions... I read that you followed the procedures in the manual... I'll just say this.. when I first did the same... it didn't seem to take ... I tried again later... and all is well...If it still doesn't work.. take it back to the dealer...
RE: Auto window
Update... Seems that the window switch in the door failed. It has internal transistors in the switch, I guess, and they failed. The dealership replaced the switch and all is well. Wow, one month of ownership and the switch fails!!! Is this a bad sign???
RE: Auto window
Well the manual say roll window all the way down and pull up on the switch to roll window up and hold switch for 3 seconds. You will hear a slight ping in the door and it should have taken, but if the switch is faulty like in my case you can do it till the sun goes down with no sucess.
