Differential mount bushings
I'm replacing the differential in a 2014 CX-9, and a couple of the bushings are in poor shape.
One of the rear bushings in the suspension crossmember is bad. I'm having trouble finding a part number for it. Does anyone have that, and can anyone recommend a tool to remove & install it?
The right mount bushing is bad (on both the old diff and the replacement). The entire mount is $150, and I'm having trouble finding a part number for just the bushing. Does anyone have that?
The rear bushings I got are Febest MZAB-143. They would NOT go in. I spent 5 hours on one, with good tools. It was 0.7mm too big. Researching later, I learned that people had ground it down to fit.
Other people used Ford 7T4Z4B425B, which is apparently also too snug a fit but easier to trim.
