Oil in Coolant Mystery
I have about 8 forums I am on activity. Friday, I get slammed with p.m.'s as well I like to post on my favorite forums some threads. .not to many as some other like to think. haha! No excuse for not being more careful about reading your detailed first post. And all the follow-ups. My general information stills good just And I S-L-O-L-Y read the first post again. lol
I think I got caught up in your testing methods which were better than most I see on forums for this kind of issue or any other issue for that as a matter of fact!!! lol
So if coolant got into the oil, then it may also be very likely that oil also got into the coolant even small amounts can cause issues. ?
I see you wrote your engine over heated but I did not see how you determined that?
pressure testing the cooling system you must got over the highest limit pressure and test not just the stated cap psi.
Just because your factory dash is in the same position is really useless unless you can get a mechanical reading or basically not using the ECU or the gauge as an indicator. If the sensor was damaged it may be giving you a false reading.
The chemical test unless you are experienced using it often times may not be accurate no matter how ell you followed the direction. Nothing personal I dont always get a positive reading and often have someone redue the test to compare results.
You said you used an OBDII reader. If it was not connected directly to the OBDII diagnostic connector and it is at least a mid-range quality or better diagnostic tool then you may not be getting true or all the information. YOu did not mention checking for pending or permeant DTCs and what about the monitors are they all in readiness? I can tell you how many times customers tell me there are no codes they checked and right in front of them I go into the ECU and ask what this... LOL
I took some picture and a short video just for you.
Today I made a short run to pick up the wife. The ambient temperature outside was 105 F. If you look there is a lot of information in the pictures about temperatures. You may also notice my transmission temperature which is not like the OEM temperatures normally associated with a stock MAZDA and what I posted earlier.
I also run a 180F thermostat to replace the 195F factory unit. I do not run Mazda FL@@ and I mix my own coolant to water @ 60/40 . I do have my own calibrated timing cycle for the radiator fans but also and more so then letting the ECU run the fans manually turn them on and off.
I don't run FL22 either, it's too expensive when the compeitior brand does the same job. I run Peak japanese coolant.
I stand by my word too, if I get this working (even just with the advice you've sent so far), I'll send some dough your way.
Thanks again. I'll report back with how it all goes tonight.
Ok so goor write up and answering questions and making comments they are a guiding help to help you...
so at this point I only can say don't go to the ECU to compare and check the dash gauge use something that is not connecting to the car.
Will see what becomes of your next cooling system cleaning?
Oh did you ever do a cylinder compression check just because? i would like to know the readings.
Thank you for the offer $$ ( I don't need it ) I do this for fun and truly like helping people. And correcting bad information MYTHs and some DIY thoughts and info on other threads ... it can be very entertaining to say the least! LOL
Okay, tests last night went great!
You called it correctly, it wasn't overheating!! After buying a laser thermometer, I ran my tests and here's how it all went down (might be too much information but the more the better in my eyes - especially if anyone else finds this thread because they're having the same issues):Temps:
The main thing though is still figuring out how oil is getting into the coolant. Overheating is clearly not an issue, but oil getting into the coolant is still problematic lol.
I did not. I'm being lazy I know, but I haven't done one yet. I might do one this weekend, we'll see.
That's very admirable. You're an asset to the car community, that's for sure. Thanks for taking time out of your day to not just help me, but anyone on here.
- 8:06pm: 74-79° baseline all over engine before starting anything. Coolant is measuring full.
- 8:06pm: Turn on engine; no strange noises or upticks. Reading codes shows nothing. Data streaming shows nothing unusual.
- 8:08pm: ODBII stream: Engine Coolant Temperature Sensor (ECT) shows 106°. Intake Air Temperature sensor (IAT) shows 74°. CATEMP11 and CATEMP21 both show 780°
- 8:09pm: Quick test of the A/C successfully turns on the dual fans. No issues. Turn A/C off after test.
- 8:13pm: After about 7 minutes of engine running and idling now. Temps are about 90-100° all over (some hoses and radiator close to 105°) slight, barely-visible white vapour/smoke coming from tail pipe but not excessive. Looks normal to me.
- 8:15pm: Top part of radiator measures 117°. Engine valve covers vary from 95-115 (hottest areas closer to timing chain side). No external leaks or anything. Coolant is measuring about mid way now on the reservoir.
- 8:17pm: Engine still looking about same temp. Radiator hoses and radiator top part measure 125°.
- 8:18pm: Parts of valve cover getting up to about 130-135° now, but most of it is staying around 100-110°. Still no external leaks. Internal instrument temp gauge still half way. Just changed cabin fan temp from 60 to 90 and turn up fan speed to get coolant moving to heater core.
- 8:19pm: Read codes again still nothing. ODBII stream: Engine Coolant Temperature Sensor (ECT) shows 170°. Intake Air Temperature sensor (IAT) shows 74°. CATEMP11 and CATEMP21 both show 852°
- 8:25pm: Valve cover and general engine temp around 110-120°, but again slightly hotter towards the timing-chain side at about 120-145°. Radiator hose is at 140-145° and top of radiator is at 140-150°. Still no extenral leaks.
- 8:28pm: Part of engine near coolant hose to top of radiator is showing about 185. Exhaust smoke is the same. Still no leaks.
- 8:30pm: Radiator hose is about 145-165°. Top of radiator is 170. Still no leaks.
- 8:32pm: Parts of engine cover near chain up to 160°. Internal temp guage still midway. ODBII stream: Engine Coolant Temperature Sensor (ECT) shows 190°
- 8:34pm: Temperature is stable. No changes. External leak; one droplet of oil near front passenger wheel. Top of radiator between 160-180°. Radiator/cooler has still not turned on.
- 8:36pm: Engine valve covers are 160-170° closest to timing cgain, rest of cover is between 120-145°. Radiator coolant hose 160-165°. Top of radiator at 175-190°. No other leaks.
- 8:45pm: After revving the engine up to about 2000-4000rpms for 20 seconds, the radiator cooler has finally turned on. Perfect.
- 11:00pm, looks to be about 4 droplets of oil now, all in different spots. Likely from my shoddy job of adding sealant to the timing chain covers after last repairs - it's not something I'm hugely concerned with but I will try to find the source today.
