Procedure to Repair Center High-Mount/3rd Brake Light
I was wondering if any of you have the procedure to repair/replace the bulb.............or is it the whole light housing? I was able to successfully remove the interior trim cover by carefully prying it with my fingers. I disconnected the lamp cord (part TD11-51-571B) from one end but am struggling to pull out the socket from the light housing. I pressed on both sides of the socket to compress the two small plastic retarders and tried pulling it out to to luck. However, the socket can go in further if pushed with the plastic pieces on the side compressed. I still do not know whether I am on the right path. Thanks in advance for saving me a trip to the dealer.
Looking at my parts diagrams this light is replaced from the outside by removing the spoiler. Looks like 4 nuts inside the interior trim panel. Remove them to remove spoiler. High mount is held in by two bolts. It is an LED assembly. Part number is TD11-51-580C. List price is $209.77. We could get it shipped to you for $170.00. Let me know if you are interested we will set something up on our website or eBay.
which tool do we use to take out side panel nut. we got very little room to use regular wrench.
Monkey Welcome to the forum
Are all assuming you have the same Mazda model and year as the one in this thread. If not I recommend to start your own thread?
You might also add a little bit in your thread how you tested the connector and also if you knew in fact the bulb was burned out?
Actually I didn't know if the bulb was burnt out. It just wasn't turning on when the regular brake lights would.
I actually tested it by connecting a 12v source. That's all I had, but it turned on. So did the new one so I know both lights are functional.
I might add again start your own thread. This thread and what you are asking does not correspond!
This thread is about the complete unit replacement not diagnosing an electrical problem.
