2001 miata speedometer problem
Old 01-29-2009 | 09:54 PM
sjbboy38's Avatar
Default 2001 miata speedometer problem
the needle on my speedometer that measures MPH drops to zero while im driving so i dont know how fast im going....the other gauges work just the needle on the MPH giving me problems....im thinking it may be my speed sensor needing to be replaced... i need some expert advise....btw its a 6 speed manual
Old 01-30-2009 | 07:24 AM
hixx's Avatar
You are probably right, See if the cruise control works when it does that. If the cruise works the sensor is working and the problem is upstream.
Old 08-06-2019 | 10:27 AM
MyBaby2001's Avatar
On your comments, you mentioned the speed sensor? I had that changed last year when my newly installed cruise control was installed. My cruise still does not work. What is the problem? Now my speedometer is bouncing and dropping to zero while I'm driving. Does it need a new speedometer cable?
Pandadug
11-08-2014 07:56 PM
Saber One
08-16-2009 07:20 AM
George
06-19-2007 07:59 PM
eugene87
09-20-2006 11:26 PM
vortilon
08-03-2006 09:57 PM
