'96 Miata Clutch pedal question
Old 06-04-2009 | 08:46 PM
NjFailSafe's Avatar
Default '96 Miata Clutch pedal question
Ok so when i push on the clutch right say im in my driveway tryin to park between two cars and u know im inching up and back tryin to get between right and my pedal basically loses pressure and since im in first gear or in reverse i stall out now theres no leak under my car and the slave cylinder doesnt seem to have wet residue on it could it be inside near where the clutch and trans come together please HELP!!!
thanks keith
Old 06-04-2009 | 09:05 PM
hixx's Avatar
Pull the rubber boot back on the slave cylinder to check for a fluid leak there then look under the dash at the firewall where the master cylinder rod comes through for signs of fluid leakage. It can be internal in the master cylinder also with no external leak. Replacing the master and slave are not really very hard or expensive.
Old 06-04-2009 | 10:20 PM
NjFailSafe's Avatar
Default thanks HIxx
hey thanks hixx one more question about that i have the manual but i cant see where the slave is located is it possible to take my front driver side wheel off and see it or should i just jack it is as high as i can and do it from under or do both take tire off and jack it up high
thanks
keith
Old 06-05-2009 | 06:50 AM
hixx's Avatar
It is on the passenger side. I would jack it up for access.
TOOLMOR
02-11-2015 09:45 PM
OziSpeed6
08-04-2013 11:27 AM
alice
07-01-2007 11:26 AM
lugz_you
05-14-2007 04:23 PM
ackerman73
09-14-2005 10:42 PM
Quick Reply: '96 Miata Clutch pedal question
