Is It common for a 1992 model miata/mx5 to leak oil?
Old 02-18-2008 | 06:20 PM
mobb2008's Avatar
Default Is It common for a 1992 model miata/mx5 to leak oil?
Hi I am the owner of a miata or Mx-5 in Australia. My model is made in 1992. I dont drive it all the time and has left the car undriven for about a month. I noticed a little bit of clear oil under the engine area. it is clear in color and not leaking at all.The lastengine oil change wasdone last october and has travelled 1500kms since then.Is it normal for miata's engine to leak a little when not driven for a while? I read from some surveys it is but would like further comments and experience you miata owners out there. Will be much appreciated. thanks
Old 02-18-2008 | 06:57 PM
Default RE: Is It common for a 1992 model miata/mx5 to leak oil?
Frankly, I don't see why the Miata would be any different than any other car, and it being a '92means that it's a veteran and probably has a fair number of miles (kms) on the clock. When they get older, they leak, unless a rebuild has been done.
My wife's Saturn has ~120,000 miles (+/-193,121kms) on the clock and it uses oil, much more than it used to.
You might try using a "high-mileage" oil next time, which has seal conditioners built into it to help old rubber from getting hard and brittle. Or old brittle rubber to soften up a bit.
We've had fairly good luck using it in her car.
Old 03-04-2008 | 03:14 PM
92mazda's Avatar
Don't know if this will help or not, but Keith Tanner, of Flying Miata, wrote a book called MAZDA MIATA MX-5 PERFORMANCE PROJECTS. In the book, on page 29 he says the following..."Miatas were inspired by old British sports cars, but the Mazda engineers decided to leave out the leaks. Well, most of the leaks anyway. There is one common one, the O-ring on the cam angle sensor used on the NA cars. This will drool down the back of the engine and is often mistaken for a rear main seal or something equally difficult to fix. The valve cover gasket will also harden with age and start to seep a little or get the plugs oily. Both items are cheap and easy to replace."
Hope this helps.
[/align]Ron
Old 03-04-2008 | 04:07 PM
'Sounds like good, sound advice to me, Ron!!
Old 03-05-2008 | 07:21 PM
SKINNEDR's Avatar
I Have a 91 Miata with over 175000 miles, and about a year ago I spent over $1600.00 for repairs to leaks that were coming from every seal and gasket and oring that existed. It is fine now and I itend on keeping him for a while...
That bady sure leak a lot....
Dex....
Old 04-18-2008 | 03:13 PM
imchilean's Avatar
it is not normal for any car to leak oil...but it is common...just because it is common doesnt mean it is normal....if you keep an accurate check on the oil level, more than likely you will have no problems....if you dont check it, you could be running your motor on less oil than it requires for optimal running and friction viscocity....oil is important for every vehicle(obviously), but in a high revving miata when you are going 80 mph and the rpms are at 4000, oil is extremely important....i would get this checked out, expecially if you plan on keeping the car for a while ormodding your car in the future....
Nzyme
06-05-2011 06:15 PM
JJohnsonAZ
04-09-2011 07:18 PM
neochroma
12-02-2008 11:43 AM
CO2Man
04-26-2007 07:06 PM
Demar002
01-17-2007 05:20 PM
Quick Reply: Is It common for a 1992 model miata/mx5 to leak oil?
