Flying Miatas mod ideas
Old 11-22-2008 | 10:29 PM
nickco201's Avatar
Default Flying Miatas mod ideas
So I am seriously looking a buying a 2001 Mx-5 racing green with tan leather and 35K miles ..... I would like to do some basic performance mods but not get too expensive...so no turbo/supercharging. I was thinking of the Using some of the Flying Miata stuff such as their exhaust headers, center section and dual rear box. Would this simply be too loud ? Also what do you think of their suspension and brembo brake packages?I think I will use AEM or K&N for CAI... From what I have heard Flying Miata makes good stuff, but I thought I would make sure. Also how much torque/ hp estimated would this add on the 1.8L ? I'm sure it would be noticable.
The other thing is wheels. Would puting say 17 inch lightweights on it have a adverse effect on acceration ? I've heard that smaller wheels say 15inch actually let it drive better... Can you really feel the reduction in unsprung weight ?
Sorry to ask so much, butThanks in advance!!
- Andrew
Old 11-22-2008 | 11:42 PM
wsoape281's Avatar
Default RE: Flying Miatas mod ideas
naturally aspirated, you are looking at only adding about 10-15 hp with a nice intake, header, exhaust combination. as far as noise, you should be alright with a flyin miata or racingbeat exhaust. as far as i know, they are 50 state legal.
Old 11-23-2008 | 09:03 AM
nickco201's Avatar
ok, thanks for the response so basically power wise it is very much so worth it to turbo or supercharge. The only thing with that is that then I would probably need to change cooling system and put a new clutch if I used one of flying miatas turbo systems. But I can esaily see how it would be worth it, but then again that probably going to be around 7K for the whole project.
Old 11-23-2008 | 11:21 AM
wsoape281's Avatar
my advice is to keep the boost low and keep the project pretty cheap. the 1.8 BP motor can take low boost over a long period of time and still be alright. i recommend to put together or find a turbo kit for under $3k and tune it for about 6-8 psi. that would put you at about 75-80 hp gain and the motor would still be safe.
if you don't want a lot of power, just to enjoy your car, naturally aspirated would be a good way to go. you will spend $2k on that though. i have built both n/a and turbo cars now and turbo comes out way cheaper for the output.
CrippleMobile
01-19-2012 12:28 AM
David Alex LaBree
05-10-2009 08:17 AM
user_mz
01-18-2007 12:31 AM
kingkong
06-13-2006 11:00 PM
jolt
04-28-2006 06:44 PM
Quick Reply: Flying Miatas mod ideas
