Intake Manifold Runner Stuck Open?
Old 12-12-2008 | 05:09 PM
turbopower87's Avatar
Default Intake Manifold Runner Stuck Open?
Our Miata recently had the check enging light come on so I took it to get the codes read and here's what they were:
P0037 O2 sensor bank 1 sensor 2
P2004 Intake Manifold runner stuck open
I've looked around and found something on a mazdaspeed miata with the runner stuck open code but they seemed to think it was something to do with a boost gauge he had put in. Ours is not a speed.
Does anyone have any clue what I should be looking for. Some pictures would be great. The car is not sluggish at all, I feel no problems when driving or idling. Should I have the codes cleared and see if it was a false alarm?
Any help is greatly appreciated.
-Neal
Old 12-12-2008 | 08:22 PM
Default RE: Intake Manifold Runner Stuck Open?
I had a problem w/the MAF sensor in my 3andit was showing 5 different codes pointing to different things.
I would be most concerned about the O2 sensor... the only one that seems makes sense.
Other than that....? I wish I had more info to offer you, but that"s all I got.
Does your Miata have a secondary intake runner throttle plate the way the MZR engines do? If so, perhaps that too is something you might look into?
Old 08-25-2010 | 09:24 PM
yazdzik's Avatar
Is it possibly you have a bad check check valve? The replacements have a yellow dot.
There is a TSB on this, for 04/05 models. It is unlikely to be a false alarm.
Good luck,
Martin
kawaxi
02-27-2015 10:48 AM
drturnip
10-01-2012 09:23 AM
thc888
01-01-2010 03:34 PM
wellerd
02-01-2009 09:37 AM
sirheadly
10-23-2005 04:46 PM
Quick Reply: Intake Manifold Runner Stuck Open?
