Miata a-c problem?
Old 10-29-2007 | 05:25 PM
CHR's Avatar
CHR
Default Miata a-c problem?
My Miata's a-c works and it's cold, but after about 30 minutes of driving, the a-c starts to squeak and make noises. What's going on here? Thanks.
Old 11-01-2007 | 05:35 PM
gnomepickle's Avatar
Default RE: Miata a-c problem?
Mine is doing the exact same thing. I've been told it needs a replacement fan belt, but I'm not sure how much something like that would cost.
Old 11-02-2007 | 03:42 PM
hixx's Avatar
I would check the belt as gnome suggests but also check the fan operation and a/c pressures. The compressor is quite a load to run but if a fan quits or the pressures get too high it becomes even harder to turn. Depending on what year it is they also had a problem with the a/c compressor bracket to block bolts falling out and causing a loose compressor which can potentially damage the crankshaft keyway and snout.
jonathanrisko
11-16-2007 12:05 AM
the_closer
03-07-2007 07:55 PM
Demar002
01-17-2007 06:20 PM
dcgun
11-02-2006 12:27 AM
eugene87
09-20-2006 11:26 PM
