oil & ticking
Old 09-13-2004 | 06:56 PM
Mazda Miata's Avatar
Default oil & ticking
I have a 96 Miata that has a ticking(like a valve). It is not losing oil, and the gauges all show that it has oil. It is obviously worse after driving for awhile...very fast. Whas'up?
Old 05-26-2005 | 08:45 AM
kalitommy's Avatar
Default RE: oil & ticking
My miata ticks when the car first starts then get better. So does my cuz's miata also. I heard it might be valve timming. You might have to remove valve cover to adjust.
Old 08-14-2006 | 01:24 AM
rob harvey's Avatar
synthetic oil fixed my ticking lifter problem right away. (96 miata 135 k)
Old 08-24-2006 | 03:14 AM
tmac4390's Avatar
the ticking is not a lifter it is the dhim buckets they get worn and when the oil gets used the ticking get louder the right thing to fix this is to replace the shims but if you use a thicker oil and a senthic it will help that would be the cheap fix.
Old 08-24-2006 | 11:51 PM
babyhuey's Avatar
All year MX-5 Miata's have hydraulic valve lash adjusters. No adjustment is possible. Probably are collapsing down and making the tick noise.
the_gray_mazda6
11-08-2013 05:27 PM
can6drvr
07-08-2008 07:13 AM
swoopes_30
06-19-2006 10:14 PM
MrSpike118
05-02-2006 06:54 PM
the_gray_mazda6
11-19-2005 01:37 PM
