oxygen sensor & fuel filters?
My miata will sputters & lose power occasionally going uphill. I've been told to change the fuel filters & O2 sensor. Does this sound right? and how hard is it to change? Thanks for helping!
RE: oxygen sensor & fuel filters?
the fuel filter depends on the year. some years have the pump and the filter integrated inside of the tank. some of them, mainly the older ones, have the filter in line. the O2 sensors are not hard to change at all.
I think is quite unlikely that the oxygen sensors are going to make the engine sputter and cough going up a hill. Fuel filter maybe but a clogged fuel filter will often just give you a feeling of power loss without the sputtering you describe.
Would be much more suspect of the spark plugs and plug wires as a cause of your problem as this is very common on the Miata. When going up a hill you are putting the ignition system and the maximum load and will be most likely to act up. Good test of the ignition system is to take off as you normally would from a stop but instead of shifting into 2nd gear, put it in 4th or 5th instead and then floor the throttle. You should feel quite a bit of power loss but should be smooth. If you feel a jerking type of sensation then the ignition system (ie plug and plug wires and possibly a coil) would be very suspect. The reason for this is that by doing this shifting into high gear thing you are putting a huge load on the ignition system but a very small load on the fuel delivery system.
I agree with babyhuey.....I'd start with plugs/wires.....although if you suspect it still has the original fuel filter (you'd be amazed at how few people change these), it's not a bad idea to change that as well before you have trouble. They're only a few bucks.
I've had good luck with Accel and MSD wires, if you've got a radio you want wires with some kind of RF suppression. I like Champion & NGK plugs myself, but realistically just about any brand will work so long as you gap it properly. Local autoparts store (Murray's or whoever) can find the exact application needed for your car. If the engine is stock, I'd just stick with what they recommend.
If you want to work on it yourself (a wise idea in my book), I'd suggest getting a Chilton's or Haynes repair manual for your car. They aren't as detailed as the factory manuals, but I find they get the job done for a vast majority of the tasks.
ORIGINAL: babyhuey
