replacement exhaust cover
RE: replacement exhaust cover
Is this the exhaust manifold heat shield that you are talking about? Is so you may be hard pressed to find an aftermarket source. Could try checking some auto salvage yards. 1990-1993 all use the same part number heat shield so should give you a broader search range to work with. Otherwise a dealer part is going to cost you $58.20 using OE part number B61P-13-380D. A little discount at www.onlinemazdaparts.com.
jsonnjon
05-26-2010 03:20 AM
kingme
05-28-2009 02:24 PM
blueblazes
04-25-2007 02:54 PM
Veneluure
07-20-2006 10:40 AM
