1999 Millenia Camshaft Gear
How do I remove the camshaft timingbelt gear from the camshaft? Is the bolt left or right threaded? I have tried 1/2 impact and a brakeover bar with no luck. I see the hex area to hold cam in place, but still no luck. I am needing access to the rear head headbolt under the camgear to remove the head. Thanks for any help anyone can provide.
RE: 1999 Millenia Camshaft Gear
your impact is puny. the cam sprocket is on there with about 100 ft/lbs. a cheap 250 ft/lbs impact aint gonna cut it. for example, the crank sprocket is on there with 120 ft/lbs, and my 600 ft/lbs impact just BARELY broke it loose.
