2001 millinnia crankshaft pulley removal
well, i dont think a 2001 is different from our 99's, but on ours, it is counter. and that sucker is ON there. even tho the torque is like 122 ft/lbs, the first time you take it off is the best. course, i just blast it off with my 600 ft/lb impact
new problem
Thanks Keninn, that did the trick. needed a new impact anyway. trying to replace timing belt and can't get left timing belt cover off. manual says to remove power steering pulley but nut's locked tight, and no room for anything but a breaker bar and the belt slips at tightest setting. Any ideas?
Thanks, but not done yet....
Ok. I broke the pulley taking it off (and busted two knuckles). Didn't know it was Plastic. Finally got the left cover off after bending and prying it through the torture chamber below. Can it go back in through the top or is there an easy way? Doesn't quite clear the cam pulley with the engine mount out...Thanks, tres
626mazdaspeed
06-26-2007 08:24 PM
phils2200
04-21-2006 03:18 PM
