95S..Starter Grinds at Startup...Help??
Old 04-09-2007 | 03:57 PM
95Miller$'s Avatar
Default 95S..Starter Grinds at Startup...Help??
Have a '95 Millenia "s" that I'm buried in but prolly not tellin you guys anything...
ANNIEWAY...Starter grinds when first started...if you'bump" a few times it will start up ok...just started doing this...please tell me it's not the flywheel! How hard is it to replace starter? Help!!
P.S. Now I know why that lear jet was in the '95 brochure...people that could afford these had all the money to repair them!!!
<center><font size=-1 face="Arial,Helvetica" font color="#004080"><b>Click on the Icon for complete description and pictures.</b></font></center>
<p>
<center><table height=70 width=440 border=1 cellpadding=2 cellspacing=0><tr>
<td height=5 width="5%" bgcolor="#FFFFFF" background="aucback.gif" align=middle valign=center><font size=-1
face="Arial,Helvetica" font color="#004080"><b>Stock #<br>TM5506</td>
<td height=5 width="95%" align=middle valign=center bgcolor="#FFFFFF" background="aucback.gif" colspan=3>
<font size=-1 face="Arial,Helvetica" font color="#004080"><b><font size=-1 face="Arial,Helvetica" font color="#004080"><b><font color="#800000"><b>NO RESERVE WATCH AUCTION!</b></font><br><font size=-1 face="Arial,Helvetica" fontcolor="#004080"><b>Burlington 16S 21J<br>Burlington 21J Railroad Watch<br><font color="#800000">Good Burlington Dial<br>Nice Gold Filled Case</font><br>Starts @ Only $99!<br><u>ENDS</u>Sunday April 8 9:00 PM Central</b> </b>
</font></td>
</tr><tr>
<td height=100 width=50 align=middle valign=center bgcolor="#C0C0C0"><A HREF="http://www.timemachinewatch.com/auctionlive/auction.cgi?action=details&stock=TM5506">
<img src="http://www.timemachinewatch.com/auctionlive/tm5506i.JPG" border=0></a></td>
<td height=5 width="25%" align=left valign=center bgcolor="#FFFFFF" colspan=2><font size=-1
face="Arial,Helvetica" font color="#000000"><b>Current Bid: $175<p><font color="#000000">On the
Bid: <font color="#800000">darlenequam@aol.com</font><br><p><font color="#000000">Last Bid: 4/2/107 - 15:51:48</b></font>
<p><font size=-1 face="Arial,Helvetica" font color="#0000FF"><b>Auction Status: Closed</b></font><p><font size=-1 face="Arial,Helvetica" font color="#800000"><b>Minimum Bid</b></font><font size=-1 face="Arial,Helvetica" font color="#000000"><b>.......
$99</b></font><br></td>
<script
Old 04-09-2007 | 06:56 PM
babyhuey's Avatar
Default RE: 95S..Starter Grinds at Startup...Help??
Only way you are going to be able to tell if the flywheel teeth are damaged is by removing the starter and rotating the engine 360' while looking at the teeth to see if they are ok or not. Starter is not overly hard to get to. It is located directly below your rear intercooler duct nest to the battery. You will also have to remove the battery and battery tray along with the intercooler duct.
Old 04-10-2007 | 11:56 AM
mazda4life's Avatar
Most likely itss just the starter. But if you keep trying to start the car with the teeth of the starter and flywheel hitting then there wont bw much left of either part. Get the starter out and have a look at the teeth on the flywheel. If they are bad then replace that too or your new starter may have similar problems.
Old 04-19-2007 | 03:03 PM
Matt64341's Avatar
I had the same problem, and it was the starter. It lasted about a month or so after the grinding started, so you want to replace it soon. I did mine myself and it was about a 2+ hour job for me. Here are the instructions i used http://www.autozone.com/az/cds/en_us...rInfoPages.htmbut be careful about the torque on the solonoid bolts because mine snapped off when i torqued it, so when i got a replacement, i just made it snug.
Old 04-20-2007 | 01:58 AM
twiztid832222's Avatar
Bro no need to spend alot of money i have a mint 95 millenia for parts. Let me know if you need the starter or anything
shagz2dopez@yahoo.com
westvilleguy
10-31-2009 11:05 AM
mzlr
11-17-2008 10:45 PM
Tracker
08-08-2007 07:53 AM
mel95millenias
12-31-2006 03:17 AM
neeltampa
10-03-2005 09:25 PM
Quick Reply: 95S..Starter Grinds at Startup...Help??
