99 Mazda Millenia S
Thanks keninn....
ALthough ypu provided me with this information, it is still a little bit hazy in my mind...do you know if there is some sort of walkthrough available online?
Regarding vacumm lines, how much do they cost?....I am in Toronto so just wondering if you have a general idea of its cost?
Thanks
Thanks
Thanks keninn....
Thanks
Thanks
Still issues...
Hey Keninn,
So I took my car to a mazda dealer ...bought the KJ03-18-741A and one of their mechanics replaced the part but the TCS lights still kicked in randomly after a while on the highway. How can I check if my hoses are messed/cracked? how much does it usually cost for hoses (roughly in US or CAD)?
The funny part is that mazda said it would take an hour to replace part..so i went to a nearby bar had two drinks came back and then the mechanic tells me oh i was looking for you to ask you which one of the four has to be replaced...which is the vent solenoid?....
I laughed at him saying aren't you the tech? shouldnt you have a vacumm diagram....anyways I showed him the 2nd from left and went for another drink and back...it was done..mechanic went home so I couldnt question him...and paid 200 CAD for part and labor.
Can you help me solve this mystery? its going to be winter in a couple of months and i wouldnt want to get stuck in cold!
Also I will get my neighbour to check the error code with his OBD 2
Thanks bud!
Thanks bud!
Hey Keninn,
Thanks bud!
Thanks bud!
it is not unusual for a mazda tech to not know about these cars. i would be surprised to find one that has actually done repair work on them. and it takes about 20 min max to change out a solenoid. a visual is the only way to really check, you can probably use a vacuum gauge, but you still have to look. and the only way to really look is to pull the intake. that's 3-4 hours at least. silicon vacuum line is available at any place that sells a lot of turbochargers. here's a place i did a lot of business with when i had my turbo cars:
http://www.roadraceengineering.com/hoseandclamps.htm
scroll down, and you will see silicone hose. cant help you with the tees tho, and they are the most important. i think grainger, or ebay.
1525 1526 engine cut out solved
following the advice of others, then replacing the two solenoids, my tcs light now does not come on and does not stumble anymore after three minutes of driving.
i found the solenoids actually on a 1990 mazda pickup. thanks for all of those who solved this problem. cost me 4 dollars an 20 minutes of work. at the junkyard however, the ohms were ok on the used solenoids, but when putting 12 volts to them they didnt actuate. so i found a couple more that did..
99 Mazda Millenia, Not Starting
I have a 99 Mazda Millenia and it won't start. I have checked to see if it is getting fuel and it is. I am not getting spark for some reason I cannot get a code reading it keeps coming up unable to read certain monitors. A neighbor said to see if it may be the crank sencor. However I don't won't to be buying sencor after sensor.. Anybody have an idea how to get a code reading.... Jack
