check engine light
Old 10-16-2006 | 02:36 PM
bmartin509's Avatar
Default check engine light
Check engine light came on again. Mechanic says that nothing is wrong with the car, just getting a false reading from the computer. he was able to bypasss the computer and test the vacuum on the egr on a dyno, everything is working fine. When computer hooked up, get the check engine light. Any solutions other than a $1000 replacement for the part?
I would even love to disable the check engine light.
2000 Millenia, 75,000. Car runs great.
Bill Martin
bmartin509@verizon.net
Old 10-17-2006 | 12:47 AM
keninn's Avatar
Default RE: check engine light
yo, this is a 2000my car, it is obd2. your "mechanic" is full of ****. the ce lite is on for a reason. if your "mechanic" is unable to figger out why, you need to take the car to a shop that can properly diagnose, and/or has the proper equipment needed to diagnose. obviously, he is in WAY over his head.
Old 10-17-2006 | 12:38 PM
theloanman219's Avatar
I have the same problem. But my mechanic and I have figured out this. There is a TSB on the computer itself. If i use Vpower gas from shell I get great milage and the car runs good for awhile. But the carbon build up on the backside of the throttle body gets really bad. The EGR valve returns get caked and sends a missfire error. If I use Mid grade or Lower grade I get a ping (almost like there is water in the gas) When the engine light comes on the car is running a little funny but not bad enough to worry. I have gone back to Vpower because of the gas mileage. I am getting a new car next week so I will not have to worry about it for much longer. Good luck with it.
Old 10-17-2006 | 11:57 PM
keninn's Avatar
we have 2 99s'. both have about 86k. i have never seen that problem, and we use shell a lot.
Old 10-19-2006 | 06:49 PM
2000smazda's Avatar
You need to read the codes before you can start figuring out what is going on! Take it to autozone or somewhere similar, and it is free!
pdw001
12-05-2022 03:54 PM
Rockstar
03-13-2015 02:07 PM
KillerTofu
09-13-2014 11:35 AM
brave-heart
04-21-2010 08:44 AM
stoogefan32
07-10-2009 08:50 PM
