Cylinder #2 misfire, need help!
RE: Cylinder #2 misfire, need help!
Hi
I am replying to this post and hopefully somebody can read and respond to my problem, because I am also pulling the same code as the original person who posted on this. I have a 96 millenia, and Its a P0302, cyl 2 misfire. I changed the plugs and wires, and also had a leaking valve cover gasket replaced, but still have rough idle and some loss of accelerating power. I had it looked at two days ago, mechanic suspects a bad fuel Injector or even worse, leakage of oil into the cylinder, since he showed me the new plug in cyl 2 as being worn out on the spark end. Not sure about that, but do you think it IS a bad fuel injector, or is it something else. Any advice would be extremely helpful.
RE: Cylinder #3 misfire, need help!
hey i hope you guys can help me cylinder 3 on my 98 mazda millenia 2.5 is missfiring i took it to a shop i replace the spark plug wires i replace the spark plugs, the distrubutor cap and the rotor the intake manifold the, massflow air sensor and the top cover gaskets because they were leaking but it still giving me the same problem
ive got a mazda 323 gxi,1.5 l petrol.i havea misfire cylinder 1and 4,ther both.linked. itested all the wiring onthe coilleads, allleads are in good working order.i had the feeling it was an e.c.u issue.soichecked it out,i put a live wire to the feedwirewhich goes to the coil leads, everytime i put a live feed to the wire and it picked up onto 3 cylinders, sofar i can only pin point the proclem to the e.c.u, anyone else know different ??? ? cheers
MazdaJohn987
01-24-2009 12:04 PM
CardsFan420
11-08-2006 07:25 PM
KuroRyu256
06-23-2006 11:50 PM
