E-brake stuck? Broken? Doesen't work!!!
Old 09-30-2009 | 04:43 AM
elitescouter's Avatar
Default E-brake stuck? Broken? Doesen't work!!!
Ok so on my 02 Mazda millenia S, the ebrake goes up easy and it doesen't do it's job. I replaced all the break pads and everything. I did notice in the back when I replaced the break pads it was hard for me to put in the new ones. The cyliner wouldn't go back in no matter how hard I pushed on it. I had to actually losen up the bleed line to push it back in and replaced the fluid. When I drive at around 50-70mph, the noise in the back gets loud as if the break pads are on the rotors at all times when I am driving. Does anyone know what I need to do to fix the e-brake problem?
Thanks
Old 10-26-2009 | 05:20 PM
gasmanrm's Avatar
Default parking brake
I have a 95 Millenia and the parking brake uses shoes on the inside of the rear rotors. You must remove the caliper to remove the rotors and gain access to the shoes. Hope this helps
Old 10-26-2009 | 09:34 PM
Victicious's Avatar
Thanks
I realized today that my E-Brake is shot also. I went to drive the car and it was running fine but when I looked down the E-Brake was fully up.
schlompie
03-06-2012 03:49 PM
Atlantabachelor
07-24-2010 01:10 PM
elitescouter
06-16-2009 04:31 PM
oderaro
03-10-2009 11:25 AM
smith3621
10-12-2008 10:14 AM
