THE IGNITION KEY IS STUCK in 2000 mazda
I've had this same problem, for a quick fix you can disconnect the battery and that will allow you to remove the key... The real issue is in the shifter... When you put the car in park there is a switch that tell the car it's in park. You need you remove the trim around the shifter to gain access to it.
rgm2744
06-25-2009 01:54 PM
