Millenia cat problem
Old 04-25-2013 | 03:39 PM
laveyj's Avatar
Default Millenia cat problem
I have a 2002 Millenia with the regular 2.5 motor. I'm getting P0431 code - which the dealer tells me is a bad catalytic converter on bank 2. They say bank 2 is closest to the firewall. The parts store says bank 2 is closest to the radiator. I just want to purchase the correct part - I have someone that will install it for me. Should I also get a replacement for the 02 sensor on the manifold (cast is attached to exhaust manifold). I appreciate any help.
Thanks. Jim
Old 04-25-2013 | 04:15 PM
Old 04-26-2013 | 07:04 AM
tanprotege's Avatar
Bank 1 is the bank with cylinder #1 in the firing sequence.
1 gal laquer thinner in 1/2 tank of gas, drive it for about 100 miles and give it a few good accelerations with wide open throttle. Also give it a good tune up.
lacquer thinner, not paint thinner.
Askme42
11-23-2012 12:13 PM
mishian
06-18-2012 07:45 PM
darkstar4100
10-03-2010 08:40 PM
Nando 6i
11-30-2005 09:06 PM
Quick Reply: Millenia cat problem
