No one knows where the Ignition coil is?
RE: No one knows where the Ignition coil is?
The ignition coil is integrated into the distributor itself. It is not replaceable or servicable. You must replace the entire distributor. Same with the voltage regulator - it is integrated into the alternator.......
The bad news is that the thing is expensive. But $200 will get a remanufactured one for you if you shop well online. The good news is that the thing is probably the easiest thing to replace on the car. Right up front. Three easy to get to screws. Pop it out. Pop in the new one. Screw it in. Voila - new distributor!
littleman626
07-27-2011 02:42 PM
