p-1525, p-0725, p-304
I am having issues with my 1998 Mazda Millenia S 2.3 3 erorr codes p-1525, p-0725, p-304 I cant seem to get any solutions on how to fix them my self if any 1 can help I would appreciate it the car will trigger the tcs light after about 5 minutes of driving and will not allow me to rev over 2500 RPM it starts to buckle I then only drive it by lightly pushing on the gas but when I restart the car it runs fine but will only allow for about 5 to 10 minutes brfore it happens again. Also I have a misfire on cilinder 4 and can not access the the last 2 rear sparkplugs behind the supercharger any suggestions.
interrnal heater not blowing hot air
I have a 98 millenia S the interior heater does not blow hot air i have also posted questions here for 3 seperate code that i seem not to have the technical savy to tear the car apart to fix so i was wondering if any 1 has an idea of the cost to fix theses problems code p-1525, p-0725, p-304 and i have replaced the front and rear suspension with lowering springs and shocks and the car now bounces alot on bumps is the car worth fixing?
on the 3 codes, i just gave you a full explanation, but if you have to pay someone to do this, lotsa luck. to change a broke tee, figger about 5 hrs labor at least. if it is the solenoid, that's easy to change, about 30 min, 1 hr max, but most likely it is also a broke tee or vacuum line. once the vacuum problem is fixed(this is why i think 1525 is more a broke tee or vacuum line problem than a solenoid), the 0725 will probably go away. the bad news is that because of the age of the car, and the texas heat, unless you change out all the vacuum lines, they will cause problems forever. figger on about another 3-4 hrs on top of the 5 to pull the intake. the 0304 is probably a coil, and since it is front bank, that is easy, 1 hr tops. a used coil is about 40 bucks, new use to be 174
by putting the lowering springs on the car, you blew out the shocks. only the rears are available aftermarket, i have seen them around 100/ea. however, these are for the 95-96 millenia, which has a different upper strut mount. so, if you get the aftermarket rears, you also have to get new upper strut mounts, because the ones on the car now wont work. the fronts are only available from mazda, about 200 each. they are a bitch to change, and if you reuse your lowering springs, you will blow out the new shocks. personally, i think lowering this car is stupid. now you know 1 of the reasons why.
it gets better. resale on a millenia sucks. a 98 in excellent condition will probably go for about 3k. in dallas, there are a couple of 01 s' going for 5k asking, and they have less than 100k miles. because of the rarity of this car, especially the 2.3(which you have, lucky you), very few shops, if any, have experience on this car. if you cheap out and find the cheapest place, more than likely they will screw it up worse. this car can eat money, you have to be very careful. if i had to pay someone to do all the work i have done, i would have gotten rid of these cars a long time ago. i think they are very well made, and perform very well, but they are fairly high maintenance.
