Please help! Car wont shift gears when hot out.
0170/73-rt/lft bank fuel trim malfunction. most common cause for this is broke tees in the vacuum line system. there are 2 in particular that break all the time. the intake must come off to get at these. this is one of those jobs that if you dont want to be doing/paying for this over and over again, what needs to be done is change out all the vacuum line(21 ft) and replace several tees. i went to brass, which will outlive the car. the plastic will only break again. also, the vacuum leak(s) could also be the cause of your 1526/1540.
1113-intake air temp sensor, compressor. this is easy to get to, just remove the plastic miller cycle cover, and you will see a cover plate with 4 bolts. this sensor is right near that plate. they generally dont go bad, i would just disconnect/reconnect it. there is a test, but you have to remove it, and put it in hot water, and measure resistance.
1526/1540-abv vent valve open or short/abv control system malfunction. this could be a lot of things. for one, it could be related to the 0170/73 vacuum line leak. another reason to change out all the lines and the bad tees. the vent solenoid is also a common problem. you can ohm the solenoid, and see, but a lot of the time, they will ohm good when cold, and when they get hot, then they fail. if that happens, then you get the limp home mode. i would change out both the vacuum and the vent solenoids, along with the vacuum lines and tees. your problems have NOTHING to do with the a/c system.
The reason I need to figure this all out is because my inspection sticker expires in November and it obviously wont pass with a CEL. However, I was really hopign to get her up to 150k miles before saying goodbye.
Thanks for your help. Much appreciated.
Is this something that I can do myself with basic car knowledge? Or am I going to be taking apart half of the car in order to replace the vacum hoses? How much would a dealer/mechanic charge for this?
Thanks, will give this a go tonight.
Twice in the last year, the gas guage would just drop the empty and stay that way for the drive. It would reset itself.
This definitly sounds like something I will not be able to do. Do you know what a fair price would be for a mechanic to do this? The reason I ask is because as much as I love this car, it might be time to put it out to pasture. It has 130k miles and has been into 2 nasty accidents (neither my fault, but not worth spending the 3-5k in body work to get it repaired...so I'm driving with my passengers side all crumpled up.
ptrshah
03-07-2011 05:58 PM
djwho
03-08-2007 12:58 AM
djwho
02-12-2007 07:37 PM
