Slight popping noise
Old 09-05-2007 | 09:03 PM
possumfat's Avatar
Default Slight popping noise
When I turn right I can hear a very slight popping noise coming from the driver front side wheel, its not very loud and sometimes can't be heard. Milly is a 96 with 61,000 miles, any ideas?
Old 09-05-2007 | 09:29 PM
keninn's Avatar
Default RE: Slight popping noise
outer cv joint. change the axle. actually, change both. they go out early. we have 2 99's, and both needed axles about 60k
Old 09-09-2007 | 09:58 PM
possumfat's Avatar
Is this expensive?
Old 09-10-2007 | 08:04 PM
keninn's Avatar
now THERE'S a subjective question. define expensive. i paid 60 bucks each for remans. i think that is cheap.
Old 09-11-2007 | 12:07 PM
possumfat's Avatar
Let me rephrase ($60.00 is cheap) my question. To have a dealer fix this problem what would you estimate the cost to be?
Old 09-11-2007 | 03:44 PM
hixx's Avatar
I would not throw axles at it just yet. There are plenty of other things that go pop. If you mean a repetitive clicking on turns under accel then probably axles, but mounts and suspension noises abound on those so verify before you buy. Dealers usually replace the outer joint if thats whats wrong. A complete axle at the dealer would be $500+.Not counting labor.
Old 09-11-2007 | 08:55 PM
keninn's Avatar
where do you get your parts at? i just checked online, a reman mazda axle is 131 bucks. 85.00 core charge, discounted price like 98 bucks. are we talking about the same thing? a dealer aint gonna change the outer joint, they will throw a reman axle at it, and be done. however, oreilly auto parts uses the same rebuilder(cardone) that mazda does, they cost 60 bucks there, lifetime guarantee. and, having owned 2 cars for the last 8 years, i can guarantee you the millenia needed axles. and, if you read the question, a slight popping noise when turning, classic cv joint symptoms. but hey, whatever floats yer boat. i'm done here. both of our cars work perfectly.
Old 09-11-2007 | 11:04 PM
possumfat's Avatar
Thanks for the response from both of you..............the popping noise almost sounds like a deep rattle than can only be heard with the windows up and the radio off, not oud at all but noticeable.
So it seems as though you were me O'Rieleys would be a good place to have it inspected and possibly fixed. How long can you drive it before you damage something?
chris16v
02-15-2020 10:51 AM
rocweiller
05-14-2009 01:14 AM
mazda_08
10-20-2008 04:09 PM
WhiteIvory
10-10-2008 09:42 PM
dbaty
02-12-2007 07:59 PM
Quick Reply: Slight popping noise
