TCS / ABS Issue
TCS / ABS Issue
1995 Millenia S with Miller Cycle engine
Had both axles replaced and ABS sensor on left front wheel was damaged. Got replaced with a used unit from salvage yard.
Car continues to act as if sensor is bad, you can feel vibration / chatter through steering and floor from left front. Do the error codes need to be reset for the computer to acknowledge the new component. The vibration was much worse prior to replacing the sensor but still not able to drive.
Also attemted to disconnect power to the system, pulled main ABS fuse, disconnected power at the proportioning valve. This actually makes it worse!
Any assistance / suggestions are appreciated, thanks.
Joeboost
12-10-2021 12:48 AM
jamcc
12-26-2006 02:11 AM
