2004 MPV tranny Flush
Old 05-01-2007 | 11:13 AM
tonto26's Avatar
Default 2004 MPV tranny Flush
I was told by the mazda dealership that i would need like 13 quarts of transmission fluid for a flush. Just wondering if this is true and if you should any mechanic be able to completely flush my system and replace ALL the fluid or should i take it to the dealership and let them handle it. I have approx 54,000 miles on the MPV right now.
I was also reading some of the posts that stated that you could replace about 3 or so quarts just by removing the drain plug on the trans, and if you do this a few times over a couple of months that maybe you would have FRESHER fluid in the tanny, not completely new, but maybe better than what it is now.
Old 05-02-2007 | 09:34 PM
babyhuey's Avatar
Default RE: 2004 MPV tranny Flush
The fluid capacity of 04 MPV transmission is 10.3 quarts. Any shop with a decent flush machine can do the same job as dealers. They all pretty much work on the same principle. Trans oil pumppushs the fluidinto a dual chamber cylinder divided by a flexible diaphram. The fluid going in on one side puts equal pressure onto other chamber with new fluid and this is pushed into the system.
You can drain a little over 3 quarts by doing a simple drain and fill but if fluid has not been serviced well and is discolored and getting burnt you will just be dilluting it down a bit. If fliud is in good conditiion then this is a very good regular maintenance practice. Did you see the post about doing the fliud flush by yourself. It works pretty close to a flush machine in my experience.
https://www.mazdaforum.com/m_41453/tm.htm
Oldschooljohn
06-24-2014 12:07 PM
b6t323
03-28-2013 12:10 PM
aralrasec
04-23-2010 09:50 PM
cuddle1979
03-08-2008 08:00 PM
wannabee
01-04-2007 10:49 PM
Quick Reply: 2004 MPV tranny Flush
