Air bag flashing pattern
RE: Air bag flashing pattern
Might want to recheck that flashing pattern sjssk. Your description is indicating a code 11 and 02. The codes should come up in numerical order and also there is not a code 11 listed. The 02 is a code for SAS control module internal failure. If this code is coming up then there is really no other faults that could be the problem. Try just turning the key from off to "run" position. Air bag light should come on for approx 6 seconds and then turn off. After it turns off then check the flashing pattern again as you did before. Code # available to be output are 1 2 3 6 7 22 25 26 32 35 37 and 91. Let know what you come up with.
ASHJ2HNO
09-24-2011 09:12 AM
kcnz1
11-09-2008 12:45 PM
Dtails59
12-05-2007 01:40 AM
