engine check light
Old 05-04-2007 | 11:07 PM
babyhuey's Avatar
Default RE: engine check light
Sorry tengleman, kept forgetting to get back to you.. If the little cable has been overstretched then it can let the indicator be off. Not sure why yours would be just stuck on S though. Try taking the end back off of the pivot, release pressure and then pull on it lightly. Should see the indicator moving. When reinstalling onto pivot make sure it is full seated. Also make sure that the cable is going under that little bendable tab and cable is within that part round cable track on the pivot area. I might be able to get some pics this weekend of our 91 that will show you the routing or have you fixed it already.
If worse comes to worse the indicator assembly is available as a separate part so you would not have to replace the entire instrument panel.
pdw001
12-05-2022 03:54 PM
Rockstar
03-13-2015 02:07 PM
KillerTofu
09-13-2014 11:35 AM
brave-heart
04-21-2010 08:44 AM
stoogefan32
07-10-2009 08:50 PM
