Help on Seatbelt indicator light
Need help on how to fix/repair/replace the seatbelt indicator light from the front panel ? The seat belt beeping sound is still ok. Tried to replace the fuse on the driver side panel, still does not light. Any suggestion. Thanks
RE: Help on Seatbelt indicator light
Is this the seat belt light that is in the instrument cluster with all of the gauges? Does this light come on when you first cycle the key from 'off' to 'run'? Sounds like maybe just the bulb is burnt out.
