MPV idle & brake problem
Old 02-20-2006 | 11:48 PM
theokengineer's Avatar
Default MPV idle & brake problem
I have a 1989 Mazda MPV mini-van with 206,000 miles on it. It ran fine until recently when the idle went from about 800 rpm to 1500-2200 rpm. Sometimes it idles up and down between 1900 and 2200 rpm when in park. Any ideas? It also seems to not break like before. It is getting harder to stop. I don't know if this is because of the higher idle or if the master cylinder or power booster is going bad. Any help would be appreciated
Old 03-02-2006 | 04:06 AM
babyhuey's Avatar
Default RE: MPV idle & brake problem
Suspect a possible brake booster diaphram ruptured. This would not only create a high idle speed due to a vacuum leak but also limited vacuum assist in the brake system. Does the brake pedal feel much harder to apply then before?
Old 11-16-2010 | 09:11 AM
rurd2go's Avatar
Hi, i am having the same problem with my 2002MPV. already change the booster and master cylinder, checked and cleaned all brakes but still having the same problem. What I notice is
brakes are better on high rpm. I would appreciate any suggestions regarding this problem,
thanks.
Old 05-18-2019 | 09:51 PM
alissafern's Avatar
Default Brake and idle problem MPV.
I am having this same problem. High idle, and difficulty braking to a stop. How difficult is it to check the brake booster? Could I diagnose this myself? And will I cause further damage if I drive the car home until I can get it worked on or get a part? I can do some small jobs myself, but is brake booster a big job?
kgzak
08-07-2015 12:23 PM
schlompie
03-06-2012 02:49 PM
j_r_42
08-06-2008 02:41 PM
REDKAISER
12-20-2007 02:52 PM
mtarajia
05-15-2007 02:24 PM
Quick Reply: MPV idle & brake problem
