No radio, gear indicator, reverse lights 1997 mpv
Old 11-03-2007 | 08:10 PM
mchathch's Avatar
Default No radio, gear indicator, reverse lights 1997 mpv
Good day, here's the situation.... 1997 MPV walked into is mid situation... told it was just a case of the neutral saftey switch. After that was complete it seems to work but now the radio the reverse lights and no gear indicator doesn't work unless the lights are turned on and then only the Neutral [N] lights up.... is there a relay or somthing cuz I am really lost. Any idea would be cool. Thks
Old 11-04-2007 | 11:27 AM
hixx's Avatar
Default RE: No radio, gear indicator, reverse lights 1997 mpv
I do not have a wiring diagram but it sounds like you need to inspect the wiring harness to the transmission carefully for poor connections or shorts as well as checking the fuses. All that goes through the CPU also.
kennich
08-05-2012 08:32 PM
kennich
08-03-2012 05:18 PM
otis
03-30-2010 11:14 AM
cleverbear
02-06-2008 02:17 AM
Lucky Chic
05-03-2006 11:00 AM
Quick Reply: No radio, gear indicator, reverse lights 1997 mpv
