2.5L engine problems
96 mx6 just swapped out a motor and canot get this one to idle. Initial start up it will foul out the plugs. Need to pinch of fuel lines to get it started even then it is hard to get going. Fuel test on the pump and regulator all check good. After running oly 2 codes came up 1195,1170 We did find the egr valve is not sealing off. Would this cause major problems? All vacuum hoses re-checked for proper location and all connections re-checked. Once running it seems to run good above 3000 rpm anything below that it just stumbles and los then eventually dies. Will restart with some effort after it is warm but if you let it set to long it will foul out the plugs during th intial re-start Lost on what to do next can some one please help!!
thakid22
08-26-2005 05:16 PM
