Airbag Warning Light
I have removed my front airbag crash-sensor modules and wiring harness. However now I'm left with a flashing airbag warning light on the dash. I was hoping there would simply be a fuse I could pull to disable the entire system but from the wiring diagram it looks as if the 80A main fuse, the 10A engine, and 10A ABS fuses are integrated. Is there a way to stop the warning light? I am afraid to bypass the harness under the hood, thinking it may deploy the steering wheel bag.
You may be able to pull the gauge cluster from the dash and remove the bulb that's flashing. I changed all the back-lighting bulbs in my older 94 mx3 rs without air bag system problems. I don't know if removing that bulb would cause any problems, so may wanna inspect the wiring to it. If it is simply an indicator light, shouldn't be a problem.
