getting an engine swap 92 MX3 gs
Old 01-26-2009 | 03:35 AM
tmoftw's Avatar
Default getting an engine swap 92 MX3 gs
I'm sure these questions are asked 100 times a day but if someone can help it's very greatly appreciated.
1. I plan on leaving the stock transmission post-swap, it seems fine. Will a stronger clutch suffice?
2. If I order a KL-ZE from an importer, will I get everything I need and can just get the engine sent to my mechanic and he can do the swap it in no strings attached or extra parts needed? I always hear things about an ECU, which I am more or less clueless on. The engine I'm planning on buying if you look in the included parts section I see sensors. Would that include the ECU? I have a link to the engine I'm probably going to buy. If your interested in giving me some good advice by checking it out here's the link.
http://www.jdmenginedepot.com/jdm_en.../MX-6/MX-3/626
Old 01-26-2009 | 09:16 AM
manofsteel420204's Avatar
Default RE: getting an engine swap 92 MX3 gs
i have reserched and some say the ecu from the 1.8 v6 mx-3 works but i recomend that you atleast purchase a probe gt or 626 2.5 v6 car's ecu and the fartest vris solinoid has to be lengthend about 5-6 inches. good luck im trying to put 2.5 in a 4 cylinder mx-3
Old 01-27-2009 | 12:53 AM
tmoftw's Avatar
well as luck would have it i found out a girl i work with has a busted 626 so id likely be able to get the ecu dirt cheap. as far as lengthening it goes, any idea how i would do that? and if ur doing the swap urself i got laods of respect for u man lol i could never have tha kind of patience
Old 01-27-2009 | 05:38 PM
Default lengthen
if you go get a wire splice kit fro your local auto part store you should be able to figure it out just cut and add a pice of wire to both thelines and crimps on ether end look up wire splice on google for some pix good luck oh and you need a 2 foot pice of vacume line like 5/16 autoparts store has that too
Juan Das Neves
08-25-2013 11:00 AM
sirial
10-14-2008 11:26 AM
Goodwrencher
09-15-2006 02:06 PM
slickmx3
01-19-2006 02:46 PM
